Old 07 Jun 2004, 03:00 pm
fritz_t_coyote fritz_t_coyote is offline
quote:Originally posted by KingKole02
Thanks for the info but what about rotors?
I know the auto pt with only front disks eats brake pads but rotors?
Does anyone know the minimum thickness of the rotors? Why would they have never been touch before and now need to be replaced? WTF?
The minimum thickness is spec'ed.
As for why they are thinner: Rotors wear out. Whenever you apply the brakes the rotor wears down the pads, and the pads wear down the rotors. And if any bits of grit get caught between the rotor and the pad there may be scoring.
Whenever you get new pads, you should also get the rotors resurfaced ("Turned": machined down to a clean smooth surface) eventually the rotor will be too thin to be safe.
Most shops will tend to err on the side of caution as improper brake performance can lead to problems with sheet metal, front crushables and the need to replace the airbags.
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
