  #13 (permalink)
Old 07 Jun 2004, 10:53 pm
tpscruiser tpscruiser is offline
Just checked our hose today while doing the oil & filter change. I can see that the hose has rubbed the transaxle case and differential cover only to the point that the braided cover on the hose was disturbed, no wear marks on the hose itself. I moved the hose/tube away from the transaxle and could see the tube rotate in the fitting going into the steering unit. I tried to tighten the fitting but it is larger than a 17mm / 11/16" and smaller than a 19mm / 3/4" wrench and there was no room to work with an adjustable.Does anyone know what size wrench will work or is a special tool required?
Guess I'll let the dealer tighten it.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
