Ingalls part # 3542PR (14mm FastCam Strut camber adjuster)
Also goes by SPC #81260
Simply replaces one strut bolt per side . . . easy driveway job.
link below for install instructions
http://www.specprod.com/PROD_DIR/C_P...t&cm d2=81260
I also have Eibachs, and installed the bolts up front for correct alignment. Make sure you tell the alignment shop tech that you have adjustable bolts up front, otherwise the tech simply inputs into their Hunter machine that you have a PT, and machine spits out that camber is not adjustable.
Rear requires shims to adjust, not bolts.
