Old 10 Jun 2004, 10:48 am
GAHOO GAHOO is offline
I had all four tires replaced under warranty, but at different times because Goodyear had two in stock an had to order the other two tires. If it is a bad tire or tires, wouldn't the steering wheel shake all of the time? Unfortunatley, the manager at Goodyear told me there is not a road force machine in the Savannah area. If is abad tire
quote:Originally posted by bigtommy83
I had a problenm like that on a minivan. Intermittent wheel shake. There was about a half gallon of water in the tires in the front. You said the wheel shook with new tires on the front, and it still did it after the rotation? Did you have all 4 replaced? Well, if you replaced them with Goodyears, there probably is a bad tire. Or a couple. If they have a road force machine, have them roadforce it. You have a roadforce problem caused by a mismatched tire and rim. Wouldn't be the first time I ever seen something like tat...or the tenth...
GAHOO
2003 Stone White Turbo
