quote:Originally posted by 53sixpack
My 2001 cruiser is starting to over heat. Gets hot then cools down when I turn A/C off. A/C cools but intermittently gets warmer then the heat goes up ands then will go down particularly when I speed up.
Is there a fan relay? what about the TSB or thermonstat?
Thanks,
If the fan is not coming on, check the engine coolant temp sensor first. This is a common problem with many cars.
