Old 15 Jun 2004, 01:10 pm
Cal Cruzer Cal Cruzer is offline
quote:Originally posted by Airbillster
It says it's a 30hp shot, seems pretty low, that's why I thought the risk would be minimal[:I]
You are betting a lot of money (an engine worth) that the risk is minimal. Do you have a wide-band 02 sensor hooked up or any other way to monitor your engine?
It looks like a squeeze trigger to activate. So you have to take a hand off the wheel to do this while you are racing? Also, hope you don't have to shift. Does it lock open or something when you squeeze the trigger so you have your hand free? Nitrous usually uses a throttle switch to activate and then turn it off at the end of the run. There are a lot of unknowns with this kit. No way would I experiment on my car with this.
