quote:Originally posted by Administrator
quote:Originally posted by PlasteredDragon
This may be the wrong forum, and I apologize if it is. When I go to edit my PTCruiserLinks profile, I only see part of the profile form... I can't see the section where I edit the signature, and the button to submit my changes is missing. When I view the HTML source of the page, I see this at the bottom:
quote:Active Server Pages
error 'ASP 0115'
Unexpected error
/forum/pop_profile.asp
A trappable error (C0000005) occurred in an external object. The script cannot continue running.
Anyone else having this problem?
Looks like you tried to get fancy and put some HTML in your sig. It bugged your Profile edit.
This forum doesn't allow HTML in any posts or signatures.
My sig has been unchanged for months. As far as I know I only used UBB code in it, and as you can see, it appears just fine. However, I just tried to edit my profile again and it still isn't showing me the whole form, and I can't edit my signature to check and see if there is any HTML or remove the offending HTML if there is any.
