Old 17 Jun 2004, 06:24 pm
Konkeler Konkeler is offline
Send a message via AIM to Konkeler
Um, no. From what I've read, they're absolute trash. Remember, if it sounds too good to be true, it probally is.
Here are what some people said from another message board I visit, this guy summed it up pretty good. I'm not sure if he's right or not, but I can guarantee you that muffler isn't nearly as great as they try to make it out to be.
Also, gas prices are starting to go down now.
I'll try to apply what I haven't forgotten from my education:
When the incoming exhaust air stream enters the Aeroturbine it is rapidly expanded due to the properties of heat transfer,
Unless this 'muffler' is heated by an external energy source, the gas will be no more expanded then it already is just by 'the properties of heat transfer'.
and then split via an airfoil cone with an orifice similar to a conical jet engine.
I must admit, it does look like the combustion chamber of a jet engine. You must realize however, that this is where fuel and spark are introduced in a real jet engine, none of which are happening here, rendering the design fairly useless.
The outer airflow velocity is increased due to the increased distance the outer air must travel.
False, it is just providing a restriction. Velocity is increased if the cross-sectional area is reduced, not distance increased.
The higher density inner air stream also creates a low pressure vacuum in the outer expansion chamber that assists in the drawing of the air out of the exhaust pipe.
Higher density would imply a lower temperature, and I highly doubt that there is a significant decrease in temperature as you travel from the outer edge of the pipe to the center. These are only ~2.5" tubes, and the amount of flow an engine creates makes for a very turbulent air stream (read: uniform). Besides, a higher VELOCITY or lower PRESSURE air stream would assist in 'the drawing of air out', not the density.
The air begins to spin because of the increased velocity and pressure transfers.
Total bull. I won't waste my time with this one.
The outer air stream then accelerates as it recombines with the inner air stream. The recombining of the air streams creates a vacuum that both muffles the exhaust sound and increases the exhaust flow. Thus allowing your engine to breathe easier and dramatically increasing your vehicles performance. The Aeroturbine allows the more efficient combustion to create the added power instead of simply dumping more fuel into your engine.The Aeroturbine achieves incredible performance and improved gas mileage while creating the smoothest low throaty turbo sound on the market.
See above. What the hell does a muffler have to do with the control of fuel supply, or worse: the efficiency of combustion?? These are two totally unrelated events (with regards to the muffler). Sounds like they cut and pasted those last couple sentences from the literature of one of those "Tornado" intake spacers.
All of that said, These douchbags (sp?) will probably make a hefty profit off this thing because most people are that gulible.
Here is picture of My Cruiser\'s Mirror
