quote:Originally posted by Gunner
Hey onedivinehammer, I was wondering what "bit" did you use on your dremel tool to do the cut out for the 2nd opening. I should be ordering my Mopar exhaust next week!!!! How hard was the install and cuting of the rear fascia? [:I]
I used a pair of shears and cut the opening a little bit undersized. Then I took the Dremel and used a sanding bit to clean it up. Be real careful when using the Dremel! It can get away from you very easily and remove more material then you had originally planned on...[xx(] Trust me, I know.
2003 GT - Patriot Blue. Mopar/Borla \"Turbo\" 2.5\" dual exhaust, K&N panel filter, AMX1397 intake pipe, dual guage pod, Autometer Phantom boost and volt guages, shorty antenna, back-up light trim rings, Streamline logo flames & antenna bezel flames(purple/blue color change), airbag flames(chrome), headlight flames, wheel center logos, billet doorlock pulls, racing pedals, Sylvania Silver Star headlight & turn signal bulbs- front & rear, \"super white\" foglight bulbs, \"clear marker\" tail lights, purple washer LEDs, hi-note horn, brushed billet fuel door, body color antenna bezel, cabin air filter.
