quote:Originally posted by RobGT
I stopped by the the dealer and their only one had no grommet!
I zip tied it for now, holds like 16 lbs and much steadier than before.
Will check the store next time.
Thanks!
Did you pull the grommet out of the factory UCP and put it in Adam's UCP? Because if you did and the part of the grommet that goes in first got torn or screwed up you can reverse that grommet on the sensor and put it in his UCP. Works like a charm and actually is in the pipe a lot more secure and won't blow out on high boost. I also purchased the sensor to get the grommet and saw it didn't come with it. Told them to take the sensor back. I was told the only way to get the grommet was to purchase the factory UCP for over a $100. That's when I reversed the torn grommet and found out it worked.[?]
