Thread: Fog lights
Old 23 Jun 2004, 09:12 am
quote:Originally posted by CREWZIN
The fog lights won't work until you have the high, low or running lights on. Do the rest of the functions on the stawk work..ie left and right turn signals, high & low beam headlights? Some owners have had problems with the multi-function stawk itself. ALSO, the number #8 fuse (15A) in the fuse panel by your left knee is the fuse for the fog lamps...check it out.
Minor correction - fog lights won't come on if high beams ("brights", and a blue light on dash lights up) are on, only low beams & running lights (first and second clicks on the same stalk you pull out). If high beams are on, pull stalk toward you, then pull outward on stalk for fogs.
