Old 25 Jun 2004, 05:02 pm
TripleJackInGA TripleJackInGA is offline
quote:Originally posted by DREAM2
Triplejack,
What launch technique did you use? My DC2 is basically stock with the exception of a K&N drop in right now. I am going to the track in a couple of weeks to see what it will run.
Did you try running with higher tire pressures and what were the results?
I'd be very pleased with 14.77 stock.
After trying many things, I found that the lower the PSI in the tires, the better it hooks, but only marginally.The stock Goodyears are just for S**** when it comes to racing, but I guess they aren't designed for that. I would like to get the Rotas and try some BGF G-Force Drag Radials on them.I preload the Torque Convertor to about 1200RPM at the tree, leave the Traction Control Off, and leave the tranny in AutoStick Mode. Some have said they do better with trac ON, but when I try it, it will brake the front tires when they start to spin, which has killed my 60' times even worse than what they are already. I think if I could hook up really good and get a sub-2 second 60' time I could make a 14.4-14.5 pass.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
