Old 29 Jun 2004, 11:42 pm
Sci-Fi Sci-Fi is offline
Yes, Booger Bushings is worth the install and cost. The OEM bushings are a honeycomb design that gives you the rubbery feel or has too much flex built into the design. Have seen many OEM bushings wear out, harden, or break after a few years of normal driving. With the solid Booger Bushings installed, you will feel/hear the transmission click/shift solidly into place and with the Hurst collar adjusted correctly to limit overshifts and the chance of cable stretching, you will be very happy with the both the Hurst shifter and Booger Bushing install. Better to change everything while you have it apart. You will be happier in the long run.
