Old 30 Jun 2004, 02:06 am
PTGT Redman PTGT Redman is offline
I use my EGT and let it drop below 800 b4 shut down. I ocassionally pop the hood cause the bay gets so damn hot and venting the heat I figure will reduce thermal damage especially over time and to sensitive stuff along the firewall.
I put my EGT probe on the downpipe too. It's not bad and for what I use it for it is helpful.
quote:Originally posted by brenner
The purpose of the cool-down is to let the tubo disapate heat and to ensure that its spinning slowly so leaving your hood open for a few hours after its shut off does nothing. I installed a pyrometer on my GT and i let it idle before i shut it down until the exhaust is under 800 degrees. normal driving around town usually doesnt get the exhaust very hot unless your always in the boost, it usually stays between 8-900 degrees, but if you get it into the boost its over 1000 degrees very quickly, and going down the highway at 60 its 11-1200 degrees. So your best bet is to always allow a minute or two before shut down if you've been driving easy for the last 5 minutes or so since the exhaust (and turbo) disapate heat pretty quickly.
Homepage:
