Old 02 Jul 2004, 11:20 am
CREWZIN CREWZIN is online now
[quote]quote:Originally posted by quicksilverdon
AND, if you're in a state like mine that tests emissions, you may not pass ...
Don, this chip/fuse thing is so easy to put in it only takes about 20 seconds. You just unhook the connector that's attached to the air sensor that's located in the air tube leading to the throttle body and put the chip/fuse into the end of it. Can be put back to OEM specs in the same 20 seconds right before any kind of testing.
