quote:Originally posted by Culprat
Jump on in the water is great,ours is a daily driver
there is no down side.
If you need help e-mail me.
I agree, very easy install if you throw away about 10 pages of the instructions [
Remove the rear bracket bolts at the manifold and the 5 front manifold bolts. Lift manifold up an support with bungee cord. Suck the coolant out with a turkey baster until the t-stat is uncovered (save the coolant in a bottle) and unbolt the t-stat housing.(This too me is the hardest part, getting the a/c line bracket of the stud to remove the t-stat housing) Lift the housing and hose up (a small amount of coolant may be lost, just replace with water). Remove the screws holding the fuel rail on and lift the rail up. Pop off the injector clips and replace the injectors, don't forget to re-install the clips. Put back in reverse order. Note; the t-stat just floats and is positioned by the housing so make sure it is positioned under the housing properly. Take your time and you will have no problems.
If you have automatic, use the instructions for the trans learn deal.
Rock on!
