Welcome buffalotr8,
It sounds from her description that they are dual-drilled for both of the common Chrysler bolt circles;
the 5 X 100mm that fits the PT and the 5 X 114.3mm (same as 5 X 4.5") that fits lots of others.
If the offset is in the 40mm range then they'll probably work just fine, but you might want to try them on (test fit) to be 100% sure they're what you want before plunking down your cold hard ca$h [8D]
Brian
(We are currently running aftermarket 17's with 215/45's that are the same outside diameter as our stock 16's, so there is no speedo error.)
\'03 5-speed S2 Dream Cruiser #1582 w/MP Stage 1 & BOV. Plastic Intake Manifold, rear Eibach springs and Supertrapp axle-back exhaust.
Crane 8.5mm FireWires & Champion Copper Plus plugs, K&N drop in filter. Chrome Plastic AMX TTAB pipe.
(Metro Detroit Area)
