Old 06 Jul 2004, 11:22 am
Todd TCE Todd TCE is offline
For the best results all adjustable shocks/struts should be turned to 'full hard' then backed of a desired amount.
In this case the Koni is 'full hard, and back 2 complete turns' for example.
The reason is shim stack preload which may vary a bit by the build. Not that 'from soft' will hurt you, just that the reverse is more accurate.
