The PT has to be one of the easiest cars I ever worked on. All you have to do is take out the power window control which pops out useing a flat screwdriver. There is a screw located behind it. Take that screw out. Pull a little bit and the AC control will pop off. Take the whole bazel off and then there is 4 screws to take the radio out. The mounting kit screws in to the same factory holes. Wire the radio to the wiring harness and then snap it in and secure the radio. Takes me less then 20 mins to do it all. Should take anyone less then 1 hour.
Ride Hard, Ride Fast, but Ride Safe [8)]
http://www.cardomain.com/memberpage/529247
