Old 14 Jul 2004, 12:34 pm
PTGT Redman PTGT Redman is offline
Even though the bar isn't there, the retainer mounts and endlink assembly bolt holes still are. Depending on you r approach, you can do it yourself, all being required is a set of ramps and some tools. If you use the Eibach sways, there is a kit with the endlink assembly. If you use a different bar, then you can get the endlink and retainer clip parts from any dealership. All it is is 2 endlinks, endlink bolts, 2 retainer brackets and their associated bolts.
I did mine, it was fun and saved me 300- in install labor.
Homepage:
