I know that the hurst shifter raises the shifter mount, and noticed that that trying to refit the shifter brackets doesn't seem go back the way it should. It seems to be alittle in the retaier clip notch area. Is this normal or should I try and re-adjust the shifter brackets so that they clear the retainer notch area?
At this point I haven't put back the interior and retainer clips. I took a test run and the shifts seem alot better. The 1st to 2nd travel is shorter. The 4th to 5th travel is ALOT shorter. The reverse imo feels about the same.
