quote:Originally posted by Beacon
Still in the CAD atm but I'll post up some renders once the design phase is done. Basic design is for 2 rear facing 10's and a pair of front facing 4way 6x9s. Also the rear deck can be mounted in the top and middle mounts. I'm happy with keeping my amp under the drivers' seat but I may play around with some recessed mounting points on the top.
Beacon, rethink the amp under the seat, if its a pretty high power amp and I'm assuming it is if you're pushing 2 10's. they put off alot of heat. I would mount it where it gets good air circulation, or install a couple computer case fans to keep air moving around the amp
my current setup is here:
I'll be redoing the system soon, amp mounted under a false cargo floor below a plexi window, subs fiberglassed into the sides of the cargo area
