Here is the link with a pic and a parts list:
You don't have to drill, The metal turbo water cooling lines are connected by a hose just under the the front elbow of the air inlet pipe between the outlet of the Intercooler and the inlet on the throttlebody. That hose (3/8 ID) can be removed and be replaced by 2 hoses connected to a 1/2: brass Tee fitting. The configuration would be like this: Out of the cooler line on top into one section of thr TEE. Out from one of the other ports in the TEE to the other metal cooler line. A 1/2 in bushing (Long neck) can be used to insert the mechanical temp probe. I know this sounds complicated but it is really not. I'll get some pics tomorrow and add them to this post. The hardest part of the whole thing is routing the temp probe thru the firewall as the probe line, connection to the gauge, and connection to the temp probe are all 1 piece and cannot be disconnected. I have my gauge connected this way, as well as Flashback2. Thats where I got the connection data from. I'll post Pics Tomorrow its too Dark to take good pics now.
AS PROMISED Here is a pic:
[img]
Parts needed:
Qty. 1 (1/2" Brass Tee fitting)
Qty. 2 (1/2" brass Male hose barbs for 3/8 ID Hose)
Qty. 4 (standard hose clamps for 3/8: ID Fuel line)
Qty. 1 (4 or 5 ft length of 3/8" ID Fuel line)
Qty. 1 (roll of teflon thread sealing tape)
Qty. 1 (autometer mechanical water temp gauge)
gauge comes with all the rest of parts needed
for installation.
