Old 02 Nov 2005, 11:57 am
Tigermilk Tigermilk is offline
Default White paint over spray on black
I have an 05 PT convert that I use daily back and forth to work. I work in the truck body industry where there is alot of painting done. The exhuast fans for the booths are vented through the roof of the building, so if the filters are not changed on a regular basis, a fine mist of white overspray settles on everyones car. It is not heavy but you can feel it on the surface when I wash it, and if you look real close you can see the fine specks on the paint. What can I do to remove this without color sanding and buffing? Maybe a clay bar?
