Old 25 Jul 2004, 08:35 am
Sci-Fi Sci-Fi is offline
Looks like to me like the original Hurst stick was replaced with a Hurst black steel one, part #238 5202. That would give an 1" left and 1 3/4" back offset that would put the shifter closer to the driver instead of the neutral or centered shift stick that comes with the PT Hurst Shifter. Usually see those sticks used on Mustangs. Only possible problem I see is that the threads for the shifter ball would be 12mm X 1.75 thread instead of the standard 3/8"-16 or 7/16"-20. But most replacement Hurst sticks can be used in other applications, the mounting holes in the sticks are drilled the same. Hurst does make round shafts in that style: in black aluminum, part #538 0202, or black steel, part #538 0197.
