Old 01 Aug 2004, 09:59 pm
Mean Green Mean Green is online now
quote:Originally posted by flashbk2
I ran mbc with zip-tied lines from the start ....never had problem with lines blowing off . However I have had the ucp pipe come off once under boost scares the f... outa ya, big pop ... and then no boost !
Be really careful with the ucp popping off. That's how my ucp came in contact with the positive battery cable and grounded out causing the frame ground to go bad. That's when I decided to cut the ucp right above the bend at the bottom and put on a coupler and hose clamps so I could turn the bottom part towards the intercooler after lining up the pipe to the throttlebody so I could use the angle Adam put there and make the clamps do their job and hold. Hasn't popped off again. If you do what I did then you can line up Adam's ucp just like the factory one and it is a nice fit.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
