Old 02 Jan 2006, 01:23 am
Chip Chip is offline
Default Antenna Bezel Replacement
This is most likely a silly question, but I need to ask.
For Christmas I was given a chroma bezel for the antenna. It looks like all I need to do is just loosen the antenna with a wrench and then lift up the old bezel and replace it with the new one. My question is this.
The antenna looks like it has indents for a special wrench to loosen the antenna base in order to lift off the old bezel. Are those indents just for show, do I need to use a screwdriver to loosen a nut that holds the old bezel in place, or does it just lift off once the antenna is removed?
This should be easy, but I do not want to start banging on the PT if I do not have to.
