  #12 (permalink)
Old 12 Aug 2004, 09:21 pm
white's Avatar
white white is offline
Have a 04GT. OK but adding the Hella horns is not really easy. First I took of the left frunt wheel because that is where the Clenton book said the horn was and removed the inside fender stuff. Not there. So this AM early I took off the right frunt wheel and there is was. But I did not have enough elect clips so back on with the wheel and back to the parts store. I also bought a plastic retainer remover tool (you really need it). Back into the garage and off with the wheel again and off with the inside fender plastic. You only need to undo the frunt part of the plastic and bend it back out of the way. Boy there is just not much room for the two horns but after about an hour of bending and saying bad things I got them hooked up.
During all of this I found that my tork wrench did not work, so I had to go to Sears and get it fixed. I also bought a nice 1/4 inch metric socket set. Getting the small screws out of the fender well plastic is really hard with out a small socket set and with out a socket and an extention I would have never, never have gotten the mounting screw holding the new horns in place. But all is well and they sound good. After that I had to sit on the back porch and have three beers and read a good book for a while.
E. White
