Get a mechanical boost/vac gauge. This way the only wiring you have to do is for the light source for the gauge.
Other than deciding where to mount the gauge (dash, A-pillar pod) this is one of the easier gauges to install. Do a search on this forums, there's a lot of info. The idea is to tap a vacuum line off the intake manifold run the line through the firewall and hook it up to the gauge. Elctric boost/vac's have a MAP sensor you have to make a bracket for and extra wire to power the gauge as well as the light source. I used a Autometer ProComp series, but have heard good things about the Lunar and Phantom lines.
Homepage:
