Old 31 Aug 2004, 08:34 pm
Gary04GT Gary04GT is offline
quote:Originally posted by crazie.eddie
Some of the roads I drive on are hilly, so instead of braking alot, I just shift into Autostick then shift into a lower gear as necessary. Is this a No-No?...
This is what the Autostick is designed to do--for hills and mountain driving. Use it like you would a stick-shift. When climbing a steeper grade I use second, watch the RPMs, then shift into third where needed. When using the Autostick to "brake" going down hills I usually use third but DO shift into second where indicated.
