Old 06 Sep 2004, 05:29 pm
crazie.eddie crazie.eddie is offline
Send a message via AIM to crazie.eddie
Thanks. The PDF will help alot. A few more questions:
According to the instructions...
quote:Perform 15 launches from 0 to 50 mph at 25% to 50%
throttle and brake lightly to a complete stop following
each launch. This will address the 1-2 and 2-3 upshifts,
as well as the 2-1 coastdowns as you brake to a stop.
I'm assuming I should hit the pedal, but only stepping down on it at about 25% to 50%?
quote:Next, drive at 40 mph and tip into the throttle 50% to
100% until you achieve a 4-3 or 4-2 kickdown. Perform
this 10 times.
I'm assuming driving the car at 40, then hitting the pedal to the floor? Should I gradually get up to the 40 mph, then hit the pedal?
quote:NO WIDE OPEN THROTTLE (WOT) UPSHIFTS SHOULD BE DONE
I'm not sure I understand the meanind of "Wide Open WOT Upshifts". Does this mean not to put it in autostick and let it hit close or above 5K before upshifting until the Quick learn is completed?
Sorry for my ignorance, but as you can see, I know nothing about cars
<b>\'04 PT GT Graphite Metalic w/Autostick: </b> Stage1, BTG Strut Tower Brace, Eibach Anti-Sway Bars, Airaid CAI, Mopar 2.5\" Dual Cat-Back (D: 14.48@93 - A/S: 14.56@90) <i>...more mods at CarDomain or PTCruiserWorld</i>
