Old 10 Apr 2006, 06:36 pm
higear4 higear4 is offline
Default Multiple Codes (P0340/P0522)
My '03 is almost 50K old and I am having two codes pop up and a few related problems. First code, P0340, is camshaft position sensor circuiit, and the second is P0522, engine oil pressure sensor/switch circuit-low voltage. Now what my car does. All of a sudden while driving my emission control light will come on. Then, while driving (manual tran) at about 3000RPM in every gear the engine cuts out abruptly. My cure for this is put the car in neutral and turn it off and then back on (while moving!). The engine cutout stops then, but the emission light remains on for a few hours or days, depending. Also, sometimes when the light is on the car will not start for a few minutes and then just comje back to life like nothing is wrong. I have had problems with plugs and wires before. I changed my plugs twice and replaced my wires once. Maybe its time for some better wires since I replaced my original ones with oems. Any info or feedback is appreciated.
