update on that mysterious rear knocking noise
I had to check it myself so heres the update.
1)not the spare tire bracket or screw. I totally took that assembly out.
2)not the gas tube since I secure it already
3)not head liner or whatever
4)NOTHING I can find is bumping into other part or even loose
5)even the bellcrank looks OK the bushing looks OK but thristed just a little I can't seem to really tell if it went bad. I also pulled on it pretty hard and it only move slightly
6) the whole wattlink seem OK unless it's a busted ball joint but if thats the case I can move it around when I pull it.
I still suspect the ballcrank is damage internally or one of those arms with balljoint is F.
I don't know and I'm VERY VERY upset at this car right now.
