quote oes you car have to be under warranty for this to be covered?
sorry to say yes. there is a new TSB that was designed to fix the problem, and involves using a paint the same color as the gray to remove and cover the marks. should only take a couple of hours. only problem, it says it follows the same guidelines as the warranty. so if your warranty is expired, this TSB may not help either!?!?![:I]
