the motor mounts are made to reduce NVH noise vibration harshness.
they have giant holes in them. I used 3M windo-weld to fill in the holes and that worked pretty good. Once you get some good motor mounts it will help to eliminate the wheel hop from spinning off the line (which is usually the cause and effect of bad mounts)
