"Those symptoms were the same as mine when I had the PCM replaced. The only problem was that they forgot to flash the pinion gear ratio in the PCM so if anyone else has simialar problem, check that before suspecting the a bad part. It was a much easier fix."
Cal Cruzer, how do you go about checking if the pinion gear ratio was not flashed in the PCM and what steps have you taken to resolve the problem.
For myself, finally gave up on S2 and ordered S1 last monday, so I want to be prepared just in case.
03 Silver GT Turbo 5-Speed
