Thanks Hyracer, I will speak with someone and see if there are any wrecks available.
Do you know if the 2Litre block will accept the tranny from an 03/04 GT?
What we basically get here is a Neon 2 litre DOHC motor.
Yes the engine did go Kboom, in fact that is now my number plate.
We are now running a Howell Automotive motor 8:6 compression with forged pistons / rods, balanced, blu printed, hi volume oil pump, Garrett ball bearing turbo with 12 lbs boost, high preasure fuel pump, port & polished head, 3" exhaust.
We get a just on 160 kw at the wheels.
From the factory they are 105 kw at the flywheel ( approx 75 to 80 kw at the wheels ).
A small improvement !
[8)]
