Thread: New Spark Plugs
Old 22 Oct 2004, 02:25 am
SteelBlueGT SteelBlueGT is offline
PTGT_Boy, Yes, I have used the round type gauge for over 30 years with no problems on regular and copper plugs. This is what Champion says about anti-seize compound: Champion recommends that you do not use an anti-seize compound, since one has already been applied to the plugs at the factory. AND NGK says: We don't recommend anti seize due to the fact it directly affects torque of the spark plug. In addition to this it can affect heat dissipation. We
don't have anything written concerning this issue.
Jon MacQuarrie
Technical Support Specialist
jmacquarrie@ngksparkplugs.com
Remember, only replace or install spark plugs when the engine is cool as diffewrent metals react to heat differently and you can damage the head if you try and and work on the plugs when the engine is hot.
