i pull the lower radiator hose
using a special connector that allows me to attach a garden hose to the lower radiator i reverse flow the cooling system. at this time i usually replace the hoses and thermostat for piece of mind. once it is filled with 50/50 mix of dexcool/distilled water i let it idle to make sure the fan is operating.
brake fluid should be changed at least every three years because it absorbs moisture. i do mine every 15-20K miles
Transmission flush and fill anywhere from 30-50K depending on conditions. I have a manual so no flushing for me just changing
Power steering is one that i have to do yet, our cruisers run the steering at high temperatures so its not a bad idea.
I put on new bosch micro edge wipers anually whether i need 'em or not
