  #11 (permalink)
Old 28 Oct 2004, 04:00 pm
Cal Cruzer Cal Cruzer is offline
quote:Originally posted by zzzhuh
Thanks to all of you!!!
I've decided to go ahead and let them do the Brake flush & the Radiator flush.
Especially since the brakes are the most important part on a car.
But I'll hold off on the power steering flush & transmission flush until I get another opinion, or until 48,000 miles when it's required.
Thanks!
Wait up there. Your brake fluid at 36,000 miles is still good unless it is eaxtemely discolored for some reason. Look at it first. I do my own and I won't be doing my 03 GT until I hit AT LEAST 50,000 miles. Even then I will inspect it first. As stated above, it is a sealed system and unless you have had some kind of problem, leave it alone.
IMHO, more important when it comes to regualar maintenance is the trans fluid. Trans fluid will break down fairly quickly and the rate of breakdown increases exponentially with any additional heating of the fluid. If your car has ever run hot for any reason in other words. Transmissions are VERY expensive to rebuild. At 36,000 I would service the trans. But go to a good trans shop. It sounds like the place you went is a rip off.
The rad flush is not a bad idea, but again, I wouldn't trust that shop...RUN!
