Old 16 Nov 2006, 08:38 am
strangelove strangelove is offline
Default AGP wastegate w/o boost control
Well I've got this AGP Wastegate just sitting here looking at me and I can't decide if I want a boost controller or a boost gauge. I like the idea of keeping the car looking as stock as possible and I'm not looking forward to running wires and gauges into the cab. So how can I install the new wastegate and adjust it manually without using a bc or bg. Meangreen mentioned that I should set it at 13 PSI any more would give me partial throttle boost. So if I loosen the arm on the wastegate that should give me 12 to 13 PSI of boost until the wastegate actuates and releases boost, right? Then from there I could increase boost be adjusting the wastegate arm as needed.
