Old 31 Oct 2004, 04:55 pm
Sci-Fi Sci-Fi is offline
Make : CHRYSLER
Model : PT CRUISER
Year : 2004
Manufacturer : DAIMLERCHRYSLER CORPORATION
Service Bulletin Num : 0900704
Date of Bulletin: MAR 02,2004
NHTSA Item Number: 10006455
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary: IRREGULAR ENGINE SNAPPING SOUND. *TT
OVERVIEW: This bulletin involves chamfering the bore radius on cam bearing caps L2 through L5 and R2 through R5.
NOTE: This bulletin applies to vehicles equipped with a 2.0L, 2.4L DOHC, or 2.4L Turbo engine (sales code ECC, EDZ, ED1, EDV, ED2, or EDT).
SYMPTOM/CONDITION: The sound may be noticed when the engine is idling in park between idle rpm and 1400 rpm at normal operating temperature. The sound is on the upper end of the engine (cylinder head) towards the front of the engine or passenger side (right side). The sound is irregular, not periodic or harmonious. The frequency of the sound will increase with RPM. The sound is more of a higher pitch snapping noise, not a low metallic knock.
