If your talking about the bolts in the lower end of the O2 housing...they just pound out. They are similar to a wheel-stud and have a splined portion of the bolt that doesn't allow it to spin. Just put a drift-pin or something similar on the broken end of the bolt and punch up toward the engine for the lower 3 bolts. If it's the upper bolt it is installed backwards from the factory and would need to be punched the opposite direction (downwards).
Deen
