Old 02 Nov 2004, 02:12 am
Grouch Grouch is offline
I have Gianelle 10 Flush that have a 35 mm offset and have no problems. The stock 01 and 02 Limited rims are a 40 mm offset. Anything between 35 to 45 SHOULD work but always test fit any rim before it's mounted. If memory serves me correctly the lower the offset the further the rim is set out towards the fender. You wouldn't think 5 mm work make much difference but I'm running Yokohama AVS ES 100 tires witch have a pretty square sidewall and the difference in appearance is dramatic
Greg Gavencky
The New Jersey Cruisers
www.njcruisers.com
