Thread: Door Problem
Old 04 Nov 2004, 03:25 pm
there is a part called the body exhauster. it releives pressure inside the cabin when that last door is closed. Yours may be blocked in some way. Try rolling the window down a touch and closing the door normally. if it closes all the way then look into the exhauster. I think it is in the back near the wheel well but not totally sure.
do the other doors close ok?
if so, then a small amount of white lithium grease at the locking mechanism should do the trick.
