Eddie, I forgot to mention a simple fix to the "hood bounce" people were complaining about.I cut 10 inches off the rear hood seal, then cut 2 inch long sections of 3/8 fuel line and inserted them into each end of the cut section of seal.I placed the section in the center and used door edge strips on each side to clean it up.there is no hood bounce and the car seems to run cooler especially in heavy traffic.There is a considerable amount of heat escaping from the hood, and there should be a low pressure area created as air rushes over the windshield.That should not only draw air from over the top of the engine,but from under the car and over the turbo. The car has to be moving to test this.
