At a temp of 70-80 Degrees My Turbo shows 15 PSI with a drop to 12 at the 5000 RPM Range.
This is on third and fourth gear on the Auto-stick. First and seccond gear the numbers are lower. This numbers are with no PCM reset. When I reset it the numbers are higher.
Ian
