Old 08 Nov 2004, 10:12 am
quote:Originally posted by Rybo Flavin
I switched the tires around and it started pulling real bad to the right.
Do you think the alignment could cause this to happen? Maybe it got knocked out of whack when the flat tire happened? Anything else I could check?..brakes?
Alignment. If it were brakes, when you swapped the original tires it wouldn't have mattered. Suspect tires wore because of mis-alignment, then when you swapped 'em the wear caused pull.
