Thread: Gas ?
Old 10 Nov 2004, 03:44 pm
Mike-in-Orange Mike-in-Orange is offline
[quote]quote:Originally posted by Jimbo
Originally posted by crazie.eddie
Stock GT is fine using medium grade. If you want better performance or if you have Stage 1, you should be using the higher octane rating.
[/quotte
ED, how about turbo lite with stage 1?
Stage 1 levels the playing field. If you start with an HO GT or a Turbo Lite and add S1 to either, you end up in the exact same place. Premium fuel is then recommended, although you could probably safely use mid-grade is needed. At around 10 cents a gallon more for premium I figure it's about a buck and half per tank more for the good stuff - so it's all I've used since putting S1 on my Lite.
