Old 11 Nov 2004, 03:46 pm
tpscruiser tpscruiser is offline
Kim,
The switch is right there at the end of the turn signal lever in the steering column. You will need to remove the covers, 2 phillips head screws just behind the steering wheel and the top and bottom snap apart. I think the switch requires a T20 Torx driver to remove those screws. Just remember to order the correct switch, the switch is different if you have factory fog lights.
Goog luck!
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
